Author Topic: Help me with a tamtech Ferrari  (Read 41775 times)
olds45512
Re: Help me with a tamtech Ferrari
« Reply #60 on: December 17, 2011, 18:59:50 »
its the best high current battery connector on the market, heres a like
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXKX39&P=ML
« Reply #61 on: December 17, 2011, 21:48:17 »
yeah i got to put the male end on the esc
olds45512
« Reply #62 on: December 17, 2011, 21:55:48 »
yep thats correct, the charger should come with a wire with deans on it
« Reply #63 on: December 17, 2011, 23:44:32 »
yeah it does, just wish i wouldn't have to change the esc plug, now i got to get a different cord for the charger and the dean plug.
waiting sucks.
why is that the best plug? just curious
olds45512
« Reply #64 on: December 22, 2011, 10:32:39 »
Most plug create resistence in the connection between the battery and the esc, deans plugs have a lower resistence than the wire does so it doesn't effect the flow of power from the battery to the esc. The battery plugs on a tyco are known as tamiya plugs and they are the worst, they rob all sorts of power and are being phased out in faver of lower resistence plugs.
« Reply #65 on: December 23, 2011, 23:32:59 »
okay cool, i ordered 10 pairs. put the one on the speed control and one on the other battery. oddly enough it came with two batteries one with a dean plug the other with a banana plug.
got the adapter for the charger charger the battery, didn't take long but the battery was already at 3.7v a cell. do lipo's hold there charge really well? cause that battery has been sitting in a box for awhile!
olds45512
« Reply #66 on: December 23, 2011, 23:45:07 »
lipos while hold a charge forever, you could charge it today and 2 years from now it will still be fully charged.
« Reply #67 on: December 24, 2011, 01:43:14 »
sweet! so they don't go bad with age like the nihm and nicd
olds45512
« Reply #68 on: December 24, 2011, 09:16:17 »
not really as long as you treat them right, like i said just make sure you dont drain them past 3.3v per cell or youll ruin them.
« Reply #69 on: December 24, 2011, 09:44:18 »
doen't the speed control you pointed me to have a cut off? or do i need to get one of those too?
olds45512
« Reply #70 on: December 24, 2011, 09:50:32 »
From what I read on the website I believe it does put I would read thru the instructions to make sure, if not you can buy an buzzer that hooks to the balance plug that will buzz when the voltage gets low.
« Reply #71 on: December 24, 2011, 10:15:30 »
PROTECTION FUNCTIONS:
1. Low voltage cut off protection: if the voltage of a lithium pack is lower than the threshold for 2 seconds the esc will cut off output power. Please note the esc cannot be restarted if the voltage of each cell is lower than 3.5v.
i believe that is the cut off :)
olds45512
« Reply #72 on: December 24, 2011, 10:59:06 »
Yep, some esc have the ability to turn it off to use nimh packs so just make sure its on and have blast.
« Reply #73 on: December 24, 2011, 14:14:13 »
ahh that is that switch, it came with a tamiya plug, well it was a smaller version but that makes sense why i way on there now.
« Reply #74 on: December 24, 2011, 17:29:25 »
so i put a deans plug on, binded the remote and receiver. which it said to turn it all off then but the receivers light started blinking again, and i have no steering or throttle. what did i do wrong?
