Author Topic: Help me with a tamtech Ferrari  (Read 27806 times)
olds45512
  • Global Moderator
Re: Help me with a tamtech Ferrari
« Reply #15 on: December 11, 2011, 19:02:09 »
the brushless motor you have is 1/18 scale and that esc says its for 1/18th scale so it should work fine.
  • Global Moderator
« Reply #16 on: December 11, 2011, 21:57:23 »
haha okay, how do you know that is a 1/18th motor?
olds45512
  • Global Moderator
« Reply #17 on: December 11, 2011, 22:27:02 »
well since the car is 1/12 scale i know its not a full size 540 motor so to next size down is 1/18 scale 380 motor.
  • Global Moderator
« Reply #18 on: December 11, 2011, 22:58:24 »
you are amazing! how fast you think it will go?
olds45512
  • Global Moderator
« Reply #19 on: December 11, 2011, 23:17:27 »
depends on the kv rating on the motor, take the motor out and see if it has any markings on it.
olds45512
  • Global Moderator
« Reply #20 on: December 11, 2011, 23:45:56 »
heres the same charger
http://www.hobbypartz.com/thac6smbachw.html
this controller is a little more but its a nicer model
http://www.hobbypartz.com/79p-gt3b-carradio-lcd.html
  • Global Moderator
« Reply #21 on: December 12, 2011, 00:10:16 »
i got the other remote, and charger on hobbyking.com
olds45512
  • Global Moderator
« Reply #22 on: December 12, 2011, 10:29:35 »
Cool, did you figure out what kv the motor is?
  • Global Moderator
« Reply #23 on: December 12, 2011, 15:49:30 »
this is what the motor says
      TACON
      96M02
2303-5200KV
olds45512
  • Global Moderator
« Reply #24 on: December 12, 2011, 17:39:17 »
Ok I will do some looking around for the trans ratio for that and try to figure out a rough guess for top speed.
  • Global Moderator
« Reply #25 on: December 12, 2011, 18:53:09 »
what does kv stand for?
olds45512
  • Global Moderator
« Reply #26 on: December 12, 2011, 20:16:25 »
Kv is a rating for rpm per volt so for example if your motor has a 4000kv rating you take 4000x the amount of volts your putting into it and that's how many rpm the motor will spin with no load on it.
olds45512
  • Global Moderator
« Reply #27 on: December 12, 2011, 20:30:18 »
your motor has a 5200kv rating and your lipos will top out at 8.4 volt so your looking at around 43680rpm and after some rough math your looking at around 40 mph give or take depending on gearing, that thing should be a handful to drive.
  • Global Moderator
« Reply #28 on: December 12, 2011, 21:31:28 »
wow, what are you using to convert rpm to mph? and these battery packs are rated at 7.4v 1800mah
olds45512
  • Global Moderator
« Reply #29 on: December 12, 2011, 22:06:00 »
The 7.4 lipo will actually be 8.4v when fully charged, as far as converting rpm to mph it not that simple. You have to know transmission gear ratio, tire height, motor rpm and from there you just have to know how to convert it all to mph. It also helps that I have a friend with the same car with a little bigger system in it that tops out at 55.
