Author Topic: TYCO 6.0V Charger Modified With Tamiya connector  (Read 4406 times)
tycoharley
« on: November 25, 2011, 12:25:16 »
Hello all i had an old tyco charger and wanted to try and use my ansmann Powerjack 6 Delta Peak 'Pro to charge the 6.0v packs up will try it over the weekend
Link to some pictures - http://s7.photobucket.com/albums/y268/Spouse/tyco%20hack/
tycoharley
Re: TYCO 6.0V Charger Modified With Tamiya connector
« Reply #1 on: November 29, 2011, 12:56:28 »
Full packs in less than 30 minutes great
« Reply #2 on: November 29, 2011, 14:01:43 »
very interesting. you think it would burn out the battery?
would it be possible to take a 12v 7ma ac adapter and convert it to take 9.6v?
tycoharley
« Reply #3 on: November 30, 2011, 01:16:51 »
The Ansmann charger out put is 8.4v at 900mah with delta v which is working fine on the 6.0v packs switching to trickle when done
Now i am thinking about the 9.6 packs and what charger to use as all my current chargers are for 6/7 cells
Not sure on the 12v charger your talking about wouldn't know were to start
