Calendar
General RC
Do you think i can shorten a Landshark tread?
Topic: Do you think i can shorten a Landshark tread? (Read 5357 times)
March 04, 2011, 19:00:47 »
the treds are super stretched.
I was wondering if i can cut a skid out and glue it, if the glue would hold that is. so basicly i guess im asking if theres glue that would hold the treads?
and what glue is that?
Re: Do you think i can shorten a Landshark tread?
March 04, 2011, 19:45:41 »
Use staples.
March 04, 2011, 22:26:51 »
really? i cut it and use superglue and it looks good not but might not hold for to long
March 05, 2011, 00:04:07 »
I stapled together the tread together for my nikko road shredder I had then put glue over it so the staples wouldnt catch anything.
March 05, 2011, 00:22:34 »
Do not cut the treads they will never hold. The best thing to do is modify the front axle so you can move it forward to tighten the treads as they stretch. Example making room to move the axle forward and usin set screws you can tighten to keep the treads straight
Administrator
March 05, 2011, 10:59:35 »
Since you've already cut the treads, someone else suggested using a bike tire patch kit.
Reply #6 on:
March 05, 2011, 18:35:56 »
it works great, treds are tight. did wheelies with it for awhile and chased my dog around and did some off roading.
It made it faster and it gets way better traction but i miss the drifting it did with loose treds
General RC
