Author Topic: Finally... another update to Conquest  (Read 4234 times)
« on: December 17, 2012, 00:01:45 »
This evening I got a little time to do something that I have been able to do only slightly more often than getting together with my gaming friends.... I got to fit in some time to do a little web dev on my version of Conquest of the Empire. Based on the timestamps of the files I've adjusted, I'm pretty sure that I started this back in August. That's not to say that I've been working on it or gotten stuck in some difficult programming problem - I simply haven't had the time.  Things just haven't worked out. But tonight, I've finally finished something that will probably only appear as a minor tweak to those who have been playing Conquest here (6sided.com). The change is on the purchase page - it now has a shopping cart style purchasing option, as long as you have JavaScript enabled. I hope that you see this as tiny taste of some good things that I have in mind for the map/movement system, which most likely won't be released until sometime in 2013.
Speaking of new things, I have a new little niece, just born today. She had a rough entry into the world, but hopefully it will be kind to her for many years to come.
